It is really unbelieveable that there is no info how to adjust CR actuator to work properly with GTB turbos on PPD engine. Problem is that CR reads opposite voltage values than stock 1749vc actuator which cannot be used with GTB turbos.
After i write map i can feel torque starting to kick in around 2000rpm, but as time passes, car gets laggy and i can hear deeper tone because turbo is opened more (its not limp mode). I suppose its due to actuator's incorrect readings sending to ecu. Turbo is new, actuator, vacuums tested with mytivac. After i write same map, it goes well.
Can anyone help me with this??
