Hello Friends,
I still having a major issue with a non start Passat 2006 3C 2.0 TDI BKP non starter.
I have already replaced:
4 injectors
High Pressure Pump
ECU Siemens
Check fuel pump in tank
and still no start, it cranks but doesnt start.
I realised that VCDS reads no 0.00 Volts at the injectors and in block 13 all 4 injectors show 0 mg/str.
Also in Engine (03G 906 016 G)
Group 018: Piezo Unit Injector Status
2.0 Injector Status Cylinder 1
2.0 Injector Status Cylinder 2
2.0 Injector Status Cylinder 3
2.0 Injector Status Cylinder 4
Does anyone know what this value means? "2.0 Injector Status Cylinder "
Thank you for your help.
4 injectors
High Pressure Pump
ECU Siemens
