tdi54
- Joined
- Dec 19, 2010
- Location
- California
- TDI
- 1981 Rabbit Diesel(sold), 2009 Jetta TDI MT(sold)2010 Jetta TDI MT, 2015 Jetta TDI SEL, DSG, 99 Ford F 350 PSD Dually, 2016 BMW X5 xDrive35d, 2016 535d
I recently noticed when I turn the heater selector to MAX on my 2010 Jetta TDI, I hear the auxiliary heater's click and shortly after warm air would flow from the vents. However, at the same time the engine rpm slowly increases to ~1000 and stays there. It does not matter whether engine is at normal operating temperature or whatever the ambient temperature is.
It never did this before, has anyone experienced the similar symptoms? Checking with VCDS, there was one fault; 01134 ecu intermittent fault 004. The vehicle runs fine with no issues otherwise. Thank you in advance.
