dustydogg31
Hello TDI Gurus, it has been a while but once again I need some assistance.
The last couple months my 04 jetta TDI has been going into limp mode. Usually I can just restart the car then limp mode would go away. Then recently the car became stuck in limp mode and it would not go away no matter how many times I restarted the car for weeks on end.
I had a friend with a VAGCOM scan the car and got code P0299 Boost Pressure Regulation: control range not reached. I did my homework on some possible causes and today I pulled the car into the garage to attempt to find the issue.
After checking vacuum lines, I hooked my MityVac directly to the Turbo Actuator and discovered the actuator could not hold any vacuum. No matter how many times I pumped the Mityvac the vacuum stayed at 0hg. So I assumed this is why my car was stuck in limp mode. So I put the car back together (had air filter and hard plastic pipe going to EGR off) and when I started the car limp mode was gone and turbo is building boost great again.
This has me confused, if the actuator could not hold any vacuum, how could my limp mode be gone?
