npdimonte
Started an oil change on my 220k Jetta and discovered that oil is coming out one of the side holes of the EGR. I also noticed my new valve cover is leaking all around the gasket area and at the oil fill cap. The valve cover issue is most likely a cheap version that I bought at idparts, it was half the cost of the OEM they were selling, replacing it with an OEM now.
Anyway, I'm concerned about this oil coming out of my EGR, I even see it on the joints IC pipes. At 200k when I did a TB change I cleaned out the intake manifold but it looks like I will have to do it again.
Why so much oil? Is it from a cheap valve cover?
What do I need to do to delete the EGR?
Thanks,
Nick
Thanks,
Nick
