RKGraves
Thanks for your help.
Daughters car - 2000 Golf ALH w/218K miles. I just completed a timing belt change. Verified the injector pump timing (VAG-COM) but didn't need to change it. Timing is half-way between the blue and green lines (slightly advanced). Also verified the fuel pressure @ 3.4.
Car idles fine, sounds good, but doesn't seem to have any get-up-and-go. In talking with daughter she says it has been this way for going on a year.
I changed the MAF sensor 2 months ago for an initial hesitation when accelerating. The new MAF correct that. No CEL. Neighborhood driving seems fine but embarrassingly slow getting on to the freeway. Eventually it will reach 70 MPH. Having driven the car when it was new I would say it has 1/2 the acceleration it used to.
What else should I check?
Thank You,
Randy Graves
CdA, Idaho
Thank You,
Randy Graves
CdA, Idaho
