jbourke367
Hey guys,
Having more problems. I replaced my starter this weekend after it went on Friday afternoon. Everything seemed to be running well. I was on my way to work this morning and the car broke down. It started with the ABS light. I assumed it was probably just a speed sensor (3 of the 4 sensors have already been replaced). Shortly after the ABS light came on I lost power to my stereo. I started getting nervous at this point as its never done this in the 5 years I have owned it. The instrument cluster froze and stopped working (the tachometer frozen at 1800 rpm or so). Finally, the emergency brake light came on and I got the flashing light with three beeps. The car began shuddering hard at low rpm and smoothed out once my rpm were higher. I am not sure what rpm this was happening at since my tachometer was frozen in place. I was able to limp up another exit until I reached a break down lane on the side of the road. I let the car for a minute or so before shutting it down. I tried starting again and I got the flickering gauges (as if the battery was dead). If I turn the key to the on position the radio works as well as the instrument cluster. I did notice this morning that my wiper motor was moving a bit slower than normal. I also noticed that the windows were rolling down/up slower than normal. I measured 11.4 volts across the battery terminals and am currently charging the battery. Has a similar scenario happened to anyone on here? I am thinking alternator issues but not sure if that is the correct place to start.
