I was having an issue with idle balance (Group 13). It would either hunt back and forth from the limits (-2.99 to 2.99) or just peg out 2 of the cylinders at 2.99. I installed a quantity adjuster of unknown condition and it did not fix the issue. I then disassembled my QA from the old repair and cleaned out all the metal that was in it. After reinstalling, it fixed my idle balance but I am having a problem getting group 19 to give me voltages that will satisfy both the lower limit and the upper limit. Currently, I have 0.940 and 4.100 volts. My volts from the last cleaning and the tolerance are listed below. Currently this gives me an upper limit fault. You can see how, if I increase the arm position, it will give me a lower limit fault. Does anyone know a fix for this? Maybe, I need to check my solder connections?
From my last rebuild:
Group 19 0.880 & 4.640 volts.
Tolerances:
Group 019 (Quantity adjuster)
Block 1;Voltage from modulating piston displacement sensor: 0.500 - 0.970 V
Block 2;Voltage from piston displacement sensor: 4.150 - 4.740 V
