robinhood949
Help please i recently purchased my passat1.9 tdi estate , that had been stood for some time, after manually turning the engine over it started first time but died straight away it did this every time i tried to start the car. one morning it started and ran fine a couple of hour later the same fault,
Its driving me crazy now some 4 weeks and replacing many parts in my flusteration ,after changing the fuel filter had a nightmare bleeding the system.I replaced the glow plugs, air filter fuel pipes vacumme pipes, checked all the obvious have even changed the cam belt and tensioners( was over due at 111K) i even replaced the temp sensor. so i tried to start again and a bit af coughing she fired up i left it running for 3 hours!. Went back to start it up again the next day and she tries to fire shudders and smoke coming out the exhaust but wont run i have double checked the timming these no air bubbles in the fuel lines please please help sorry about the long thread just want to save peoples time and give an idea thanks everone
