Old December 14th, 2006, 14:28   #1
deemil
Default Fuel pump leak
Hello All, my fuel injection pump is leaking, can it be fixed cheaply. There is an odd shaped bolt and some torx bolts holding the piece thats leaking together. What tool can be used to remove the odd shaped bolt.
Would like to add pic, but haven't figured that part out yet.
deemil is offline   Reply With Quote
Old December 14th, 2006, 15:59   #2
Birdman
Fuel Economy: 55 summer 50 winter
Check with metalnerd in the vendors section. He sells them.
Birdman is offline   Reply With Quote
Old December 14th, 2006, 21:55   #3
Rexking414
TDI(s): 02 jetta
Fuel Economy: Around 41 Mixed driving
What kind of fuel are you using? Biodiesel? THis is starting to get interesting.....
02 Jetta TDI Indigo Blue 100K miles Hex-Com+CAN, Mudflaps,
Pending Mods:ESP, Rear fogs with Switch, FIS cluster, MultiFunction Wheel
Rexking414 is offline   Reply With Quote
Page generated in 0.12638 seconds with 10 queries
[Output: 51.54 Kb. compressed to 46.42 Kb. by saving 5.11 Kb. (9.92%)]
