bhodgkiss
Hi All
Today a friend fitted R520 5-hole injectors to his car (11mm pump, previously had 0.280s running great, BV43 etc) it's running my remap
They were set up by one of the main places in the UK who do this, and they set the pop pressures etc. (They also did his 0.280s which are great)
It's misfiring on one cylinder under full load.
Static timing fine, idle IQ is fine, group 13 shows the injectors to be very well balanced.
No faults with VCDS.
The timing is erratic, which I presume is effect and not cause.
We threw the 0.280s back in and great again
No obvious damage to injector #3 wiring, and again no faults.
Copper washers were new.
I presume one injector is clogged? Any thoughts please?
Currently we plan to return them to the place that calibrated them.
