Hykojeff
Hi everyone I have a 2006 VW Jetta TDI 1.9 I replaced the turbo and transmission. I have an issue with the turbo control. Appears that the issues is that when I start it up I get full vacuum constantly to the actuator. If I unplugged the vacuum line or N75 or MAP sensor then I have no vacuum and the actuator is fully closed allowing full boost. Otherwise the car is in
Imp mode and no power since the turbo stays fully closed. I don't have a VAG COM and I don't have the funds t go out and get one. I replaced the N75 and no change. As I said if the turbo vacation line is unplugged I can start and drive it. With it plugged in it has no power and blows black smoke. I have checked every fuse inside I'm the left upper side fuse box, and under the hood by the battery. NEED HELP, ANY HAVE A VAGCOM AND WILLING TO HELP ME OUT HERE IN UTAH SALT LAKE WEST VALLEY CITY AREA? Yes I did check wiring etc,and I'm sure I'm missing something simple. Maybe it's just a reset needed with a VAGCOM?
