chenyichung
The H11 ion bulbs don't have a gap to lock into the OEM fog light lamps i have for my 2006 VW Jetta TDI.
pic1
pic2
Please look at pic1, boxed in red, the 9006 bulb has a gap so that when inserted into the fog light lamp, you can twist the bulb to lock it into the lap
Also in pic1, circled in yellow, the H11 ion bulb does not have a gap, so I am unable to insert the bulb all the way into the fog light lamp, hence I am unable to twist and lock the bulb into the lamp
Now please look at pic2, circled in red, the 9006 bulb has a pin at the top, there is no slit for the pin to slide into the female plug on my euro-OEM fog light wiring harness.
Also in pic2, circled in yellow, the H11 ion bulb has a pin at the bottom. There is a slit for the pin to slide into the female plug on my euro-OEM fog light wiring harness, however because there is no gap on the H11 bulb, I cannot slide the bulb all the way into the fog light lamp.
What I need is a bulb with the gap like the 9006 bulb, but I need the pin to be on the bottom like on the H11 bulb, does this kind of bulb exist?
so yea, basically my situation right now sucks.
9006 bulbs do lock into OEM fog light lamps, but won't plug into female plugs on wiring harness
H11 bulbs will plug into female plugs on wiring harness, but can't slide in all the way to lock into OEM fog light lamps.
Please help...
pic1
pic2
Please help...
