How can I visually identify a VNT-17/22?
diesel_micah
Atlantic Canada
2001 Golf TDI
I have an opportunity to buy a turbo that was bought by somebody for a project that they abandoned. The turbo is brand new and never installed.
I'm told it is a VNT17/22, but there's no receipts to go with it as it was purchased a few years ago and they got lost along the way.
What concerns me is it's stamped Garrett "GT1749VA."
I know the "good" VNT17 is the "GT1749VB" version... But I do know that a 17/22 is a customized turbo, maybe the builders just used a different compressor housing ? How can I be sure before I buy as I can't exactly disassemble the turbo and measure the compressor diameter before purchasing.
kiwibru
Distant island in WA. state
Golf 2-door, 2k Silver. Red RTDI now gone but not forgotten!
diesel_micah
Atlantic Canada
2001 Golf TDI
This might help....
The 17/22 hybrid adds a larger 52mm compressor wheel and housing to the VNT17 (1749VB) hot side. Getting hard to find and when you do they are expensive! Lots of movement towards the newer GTB and GTD series like 1756 purchased from EU sources.
http://pics.tdiclub.com/showphoto.php?photo=129593&title=f17-22-turbo&cat=7017
Hey thanks for the reply. I noticed right away the compressor housing in your photo looks like the VNT15 style. Here's a photo of the one I'm looking at:
South of Boston
That's not what Garrett would assemble as a 17/22. The compressor housing looks like it's from a VNT-17. Perhaps internals are modified, but the point of the 17/22 is the larger compressor housing to help airflow and spooling. And if it's labeled a VA it may be limited to 22 PSI boost instead of the 24 that a 17 VB can do, or the 28 that's a reasonable limit with a 17/22.
Is the hot side of this turbo one piece including the manifold? Can't see it in the photo. If not, it's probably a VNT-17 from a B5.5 Passat or similar. There a many better options for your car.
diesel_micah
Atlantic Canada
2001 Golf TDI
Interesting. Here's the other two pictures I have of the exhaust side:
South of Boston
Turbo body looks like a normal VNT-17, not a 17/22. But that exhaust wheel looks different from stock, at least to me. So maybe it's modified.
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
diesel micah,
May I suggest before you spend more money on a turbo, go for a PD150 intake. That'll deliver a LOT more air. You've clearly got the mods, what are you trying to achieve? You racing the car?
After my recent install of the above, I'm in need of a remap of the fuelling side of things for my daily driver. I had to shift my IQ 5pts
to accommadate the extra flow.
I love my 17/22 and current setup with .230 Wuzetem nozzles. I could easily get more out of the engine, but at the cost of longevity
& reliability if I pursued the quest for MORE.
Got a 3bar map? Suspension? How much do your wheels weigh?
My $ .02 FWIW.
diesel_micah
Atlantic Canada
2001 Golf TDI
diesel micah,
My $ .02 FWIW.
Hey, thanks for the reply. I'm actually running a PD150 intake and 3bar. I've got a great setup now running 20psi at the intake. Happy with the power for sure! However I was thinking if this turbo actually is what the seller claims it is, it would be a solid deal for the price. I have another ALH motor I'd like to build once my beater TDI rusts out completely (LOL)
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
If your going to build an ALH why even use a 17/22?
Rrusse11
PA Deutsch Country
Satin,
So what turbo would you recommend and why? Like Micah, I got
a deal on an unused 17/22 for $800. With a $15 inlet hose I was good
to go. The biggest hassle with the installation was stretching the hose over the bigger inlet. Push it hard with the IQ at 9, I can still hit limp mode, and the turbo will spike to ~ 30psi. The addition of a boost gauge has given me a much better sense of what the turbo is doing.
Hence my need for a tweak on the fuelling map.
I'm going with TDI_Meister's approach of big nozzles dialed back.
Hopefully sacrificing ultimate performance potential for longevity.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
If you are going to actually build an ALH. Using a 17/22 seems futile. Any gtb set up would be more efficient and durable. Cost might be a little more with a tubular manifold but will probably outlast a 17/22 ten fold and take way more boost. Whatever you want to do is always up to you. I just don’t see the use of such a small turbo for a build.
kiwibru
Agree with YBS on this. The turned out outlet pipe on the photo sure makes it a 17 body. Go GTB or GTD, newer generation, spin like mad with those ball bearing shafts!
