Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old March 8th, 2011, 08:51   #1
mikey141414
mikey141414's Avatar
Fuel Economy: 32 in the Rogue, 99 MPGe in the Sonata
Default Turning Rotors in Wichita, KS?
I'm looking for a shop that will turn my rotors here in Wichita. Anyone had it done that can recommend a good shop? And about how much does it cost?
Thanks,
Mikey
Mikey I'm out of the VW game for now. Hopefully I find myself in front of a TDI badge again!
--Experience varies directly with equipment ruined.--
mikey141414 is offline   Reply With Quote
Old March 8th, 2011, 11:33   #2
vwjettadsl
vwjettadsl's Avatar
I've found that you're better off to spend the extra money and get new rotors, turned rotors never worked good for me.
my $.02
Trusted TDI Mechanic
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer tunes for ALL TDI's
www.MidwestTDI.com
vwjettadsl is offline   Reply With Quote
Old March 8th, 2011, 11:37   #3
truman
Typically, turned rotors will work for maybe a few thousand miles, then will have to be replaced. Rotors aren't very expensive anyway.
truman is offline   Reply With Quote
Old March 8th, 2011, 11:39   #4
dieseldorf
top post dawg
dieseldorf's Avatar
Mikey, don't bother. Rotor are cheap and these typically don't hold up well to machining.
Old March 8th, 2011, 13:14   #5
mikey141414
Thats what I was wondering, if the price of getting them turned was much less than getting new ones. Bora parts has rears for $26 and fronts for $80. Does that sound right? WHy are the fronts so much more?
Old March 8th, 2011, 13:16   #6
vwjettadsl
vwjettadsl's Avatar
Local parts stores should be about $30 each for the fronts.
www.MidwestTDI.com
Old March 8th, 2011, 13:18   #7
dieseldorf
top post dawg
dieseldorf's Avatar
Fronts are vented and heavier.
Rotors are not expensive, there are many choices. Just get something that is OE grade, not C.R.A.P.
Old March 8th, 2011, 15:09   #8
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Yep. And they will be just fine. You can get the premium ones for $35-50.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old March 8th, 2011, 15:10   #9
jasonTDI
jasonTDI's Avatar
Actually a lot of places will sell ISO certified quality Chinese rotors. There are the Prothe rotors but the Bumper to Bumper or NAPA ones are just fine.
Old March 8th, 2011, 15:55   #10
davrink
Fuel Economy: 46 mpg VW, 20 mpg Dodge
I bought a rotor for the front that turned out to be better designed than the original equipment. It now has 50,000 miles on it and no problems.
2002 Jetta sedan TDI-- Ventectomy, Superbright LED mod for cabin and trunk, Diesel Geek Full Metal Jacket, Glow plug time extended.
davrink is offline   Reply With Quote
Old March 10th, 2011, 05:49   #11
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
A good shop won't turn your rotors.
From the Bentley, FS III calipers, Front rotor (vented):
Thickness 22mm
Wear limit 19mm
Rear rotor (solid):
Thickness 9mm
Wear limit 7mm
Unless you've got a lathe in your garage it's gonna be cheaper, safer & easier to put on new rotors. And if you do, it's still safer!
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old March 10th, 2011, 07:26   #12
mikey141414
Thanks for the advice everyone! This is one of those areas that I have been unclear on for awhile, but never really bothered to figure out. I ordered some OEM rears yesterday from my local VW parts store. $36 for both rears. I'm pretty sure this is where my wobble is coming from. I can hear a squeal when going in reverse.
Thanks everyone!
Any TDI mechanic in Wichita, KS? suparag Mid-west USA 2 January 24th, 2008 15:18
Tools around wichita,ks? 04tdiwagon Mid-west USA 7 July 23rd, 2007 20:28
Wichita, KS TDI Owners BadgerMan TDI 101 7 December 27th, 2003 10:53
Trip from Minneapolis to Wichita, KS Leseid Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 4 May 17th, 2003 06:02
any good mechanics in Wichita, KS? jayhawk Mid-west USA 0 August 8th, 2001 23:43
Page generated in 0.16841 seconds with 11 queries
[Output: 111.96 Kb. compressed to 94.29 Kb. by saving 17.67 Kb. (15.78%)]
