****Those with Boost Gauges look here****
red golf tdi
Vendor , w/Business number
Minneapolis,MN
1999.5 Golf Red
For those who have boost gauges...
1.Are you chipped or stock?
2.What brand of gauge do you have?
3.Where is it tapped into the intake? (ie-piping or intake manifold)
4.Peak spike boost in PSI?
5.Leveled off boost in PSI?
6.Highway cruising boost level ground at 70-75 MPH?
7.K&N Airfilter?
8.Miles on the engine?
red golf tdi
Minneapolis,MN
1999.5 Golf Red
1. Chipped (UpSolute)
2. VDO
3. Intake manifold
4. 29 PSI peak
5. 18-20 PSI leveled off
6. 3-4 PSI Hwy cruising
7. Yes
8. 103,000
runonbeer
Maintenance EnthusiastVendor
Austin, TX/Chapel Hill, NC
'00 Golf 02M, '10 Golf 02E, '02 UTE 02M
1. stock
2. crown, cork & seal. (CO2 gauge)
3. Intake pipe (upper post IC(
4. 17
5. 8-9
6. 2-3 (5 on a hill)
7. good 'ol stock airbox
8. 90K (already)
1. purpose of this survey?
dlai
The Insane Asylum Known As CA
2005 Passat, Stonehenge Gray, 2002 Black Golf 5M
1. Upsolute Stage 3
2. VDO
3. Upsolute intercooler pipe with tap
4. 24 psi
5. 22
6. 5 highway cruising
7. No
8. 63k
oldpoopie
Portland Oregon
2001 golf gl, 2006 jetta, 1981 ALH swapped rabbit pickup, 1998 beetle
1.Are you chipped or stock? Upsolute
2.What brand of gauge do you have? Autometer
3.Where is it tapped into the intake? (ie-piping or intake manifold) Dieselgeek race pipe.
4.Peak spike boost in PSI? 21
5.Leveled off boost in PSI? 17
6.Highway cruising boost level ground at 70-75 MPH? 5 -6 ish
7.K&N Airfilter? amsoil panel filter
8.Miles on the engine? 70k
Stealth TDI
Pre-Forum Veteran Member
Newport News, VA
2017 GTI APR Stage 3 (395 hp/376 lb-ft)
Hi,
1. Upsolute Chip
2. VDO
3. Tee'd off the ECU boost line (IC pipe... my car is an A3)
4. Peak Boost is 20-psi (limited by Dawes Device)
5. Sustained Boost was 16-psi, but I'm bled to 18-psi
6. 5-psi Cruising at 75-mph
7. Bosch Paper Air Filter
8. 145,000-miles on engine
Take Care,
dzljet
TEXAS
00 Jetta
1.Are you chipped or stock? Yes and No, I have Upsolute and Wett 1.23 bar and std programs but I'm using stock currently
2.What brand of gauge do you have? Had a VDO, getting a Autometer Cobalt Blue soon.
3.Where is it tapped into the intake? (ie-piping or intake manifold) Now I'm Utilizing Dieslegeek IC pipe with tap built into it but I also tapped into stock IC pipe on long flat side and it produced good measures just a bit more work to get hooked up versus D'Geek set up.
4.Peak spike boost in PSI? Stock 17 psi, 205 injectors 24 psi, Wett 1.23 with 205's 27 psi, Upsolute with 205's 27 psi, std Wett program with 205's 24 psi
5.Leveled off boost in PSI? Upsolute 18PSI, Wett 15psi using a Dawe's device.
6.Highway cruising boost level ground at 70-75 MPH? 2-3 psi
(who drive's 75 mph??)
7.K&N Airfilter? Piper panel installed but prefer a Viper installed.
cyclonecoasters
Solebury, PA
2012 Passat TDi
1. Upsolute w/ Upsolute tuning box
2. VDO
3. Tapped out of DG Race pipe
4. Spiked 21lbs/ after boostvalve 16 lbs
5. Levels off at 12+ lbs
6. 4-5 lbs at cruise
7. Viper air breather and pre-filter on snorkel end / 2.5" cat-back exhaust without muffler
8. 28,000
Mahoutsukai
Phoenix, AZ
1. Chipped (upsolute), Kerma .205 (Sprint), and boostvalve
2. VDO
3. IC pipe
4. 18 PSI
5. 16-17 PSI
6. 2-3 PSI
7. Amsoil (direct replacement for stock filter)
8. 25,000
BawlsyTDI
jetta, someday a getta, 2001, baltic green
3.Where is it tapped into the intake? Rubber intercooler-EGR hose
4.Peak spike boost in PSI? 20
5.Leveled off boost in PSI? 16-18
6.Highway cruising boost level ground at 70-75 MPH? maybe 10
7.K&N Airfilter? STOCK AIRBOX!!!
8.Miles on the engine? 63,000
ChrisB.
Bel Air, Md.
Stepfather of an '03 Jetta TDI, still miss my chipped 1999 Bright Blue NB Totaled 10/2011; 2011 TR GTI, 1998 NB 2.slo0
1. Wett
2. VDO
3. IC Pipe
4. 26 PSI spike
5. 2-3 highway a2 75mph
6. K&N
7. 86K on car
GeWilli
lost to new england
none in the fleet (99.5 Golf RIP, 96 B4V sold)
1.Upsolute + Sprint 520 Kerma nozzles
2.Medical Device Gauge (from Ben L.)
3.piping
4.28+ (withdawes installed to break at 18 psi)
5.18 tapering down to 16 with extended sustained boost
6.5-6
7.Amsoil Panel
8.150,500 miles
WindWagen
Toronto, Canada
1. Evry Mod
2. Office shop's junk pile pneumatic gauge
3. Tapped into the side of plastic tube just above IC, closer to the washer bottle
4. 17 psi
5. 14 psi
6. 3-4 psi
7. Nope..don't believe in them
8. 11,000 mi
NoJoke
1. Chipped
2. isspro
3. intake manifold
4. 26
5. 18
6. 4
7. amsoil foam
8. 65,000
PI71
san antonio,tx
2001,jetta,5speed,green,tan leather interior
A
azbioguy
Guest
1. Upsolute, Kerma PP 520 nozzles
2. VDO
3. Upper IC pipe
4. 20PSI limited by boostvalve
5. 17-18PSI
6. 3-4PSI
7. Nope
8. 24,000
JOE OLEARY
Flint Mi.
1.Wett 1.23 Bar W/205's
2.Autometer prolite
3.Joe brand intercooler pipes,pre and post turbo.
4.20 psi
5.16 psi
6.3-4 psi(I think)
7.K&N Panel W/3" CIA
8.92K
dzcad90
Rolex & gin
Joliet, IL USA
Jetta - 97 (RIP), '03 (Sold), '09
1. Chipped (Upsolute)
2. Autometer 5404 Liquid Filled 0-30 PSI
3. Piping about 1-2 inches past boost sense nipple
4. 23-24 PSI when cold, about 21 when warm
5. 19 PSI
6. I'll check tomorrow, I'm guessing around 8-10 PSI.
7. OEM Paper filter
8. 109,xxx
Note this is an A3 Jetta with a 1Z engine.
NothernSky
Monterrey, Nuevo Leon MEXICO
Jetta, Model 2001, red
1. Upsolute, Kerma PP520 nozzles
2. VDO
3. Upper DieselGeek IC pipe.
4. 25 or more, want a 20PSI limited by boostvalve(still hasn´t arrive)
5. 19-20PSI
6. 4-5PSI
7. No
8. 47K
TDI2some
Western WA
2005 PassatTDI GLS, 2003 Audi A4q 1.8t, 1975 Rabbit (waiting for TDI transplant)
-Stock
-VDO
-I.C. Piping
-25 PSI
-18-20 PSI
-3-5 PSI
-NO
-66,000
A
azbioguy
Guest
Reviving this long dead thread...since it has some interesting data! Post your results!
1.Are you chipped or stock? Upsolute Stage II and PP520 nozzles
2.What brand of gauge do you have? VDO
3.Where is it tapped into the intake? (ie-piping or intake manifold) Upper IC pipe
4.Peak spike boost in PSI? 20PSI (no boost valve/dawes)
5.Leveled off boost in PSI? 16-17PSI
6.Highway cruising boost level ground at 70-75 MPH? 3PSI
7.K&N Airfilter? NO
8.Miles on the engine? 47500
MrCaddy
Singapore
1.Are you chipped or stock? Chipped, Nozzles
2.What brand of gauge do you have? Autometer SportComp
3.Where is it tapped into the intake? (ie-piping or intake manifold) IC piping just before EGR
4.Peak spike boost in PSI? 21PSI
5.Leveled off boost in PSI? 16PSI
6.Highway cruising boost level ground at 70-75 MPH? 5PSI
7.K&N Airfilter? No
8.Miles on the engine? 126,000KM
Superlite
Belgium
Golf 3 GT-TDI 110, 1996, Mystic Blue
1.Are you chipped or stock? no chip 0.216 nozzles (dsla150p502)
3.Where is it tapped into the intake? intercooler piping
4.Peak spike boost in PSI? 18-20
5.Leveled off boost in PSI? 15
6.Highway cruising boost level ground at 70-75 MPH? 4 (after a more thorough check
7.K&N Airfilter? yes
8.Miles on the engine? 227.XXX km
03_01_TDI
Banned
Denmark
Na
1.Are you chipped or stock? <font color="red">no </font>
2.What brand of gauge do you have? <font color="red"> whatever came with 42dd kit </font>
3.Where is it tapped into the intake? (ie-piping or intake manifold) <font color="red"> uper i/c pipe with t fitting and a reducer to prevent the humming</font>
<font color="red"> 29
</font>
5.Leveled off boost in PSI? <font color="red"> 12-14 </font>
6.Highway cruising boost level ground at 70-75 MPH? <font color="red"> 4-6</font>
7.K&N Airfilter? <font color="red"> no </font>
8.Miles on the engine? <font color="red"> 61xxx </font>
Other mods are race pipe, no cat, high flow muffler, heat wrap on the down pipe, heat wrap on the upper portion of the exhaust manifold to prevent heat soak into the intake mainfold, OldMan intake that is also heatwrapped to prevent heat soak.
Yes the car spikes at 29psi I've got a standby pd150 turbo.
Toronto_Vento
Richmond Hill, ON
01 Baltic Green Bora
I guess I'll chime in:
1. Stock
2.VDC
3. Piping (there is a location from factory on the A3s)
4. 14 PSI
5. 12-14 PSI
6. 6 PSI
7. Nope...paper airfilter
8. 170 000 kms
This info may soon change at the fest.
GuyGuy
Rockland Ontario, Canada
2012 Passat Comfortline DSG
1.Are you chipped or stock? Upsolute stage 1
3.Where is it tapped into the intake? upper piping close to fuel filter
5.Leveled off boost in PSI? 14
7.K&N Airfilter? no
8.Miles on the engine? 70,000
