So I have recently replaced my inner outer tie rods, ball joints, wheel bearings, control arms and bushings, as well as the spindles. I took my car in for an alignment due to all of the part changes, and they were able to aline the toe but could not get the front right camber to come into spec, the front left is fine and both the rears are perfect. I know that there is very little adjustment in fact the only adjustment you have is the 3 bolts in the ball joint and that is very limited at best. So what could throw my front right camber out by -1.8 degrees? and how can I get it back into spec?
