P0128 after new sensor and thermostat
Von Elling
Colorado Springs, CO
2005 golf gls tdi
Hello everyone,
I appreciate you taking the time to read and address the concerns brought up by us less knowledgeable newbies. So, thank you in advance.
I have an 05 Golf TDI which has a persistent P0128 Code. I replaced both the termostat and coolant temp sensor with no luck. I had autozone clear the code and it came back on immediately upon start-up. What gives?
UhOh
PNW
Did you test the thermostat before installing?
Where did the CTS come from? Crap ones are out there.
Check wiring to the CTS.
oilhammer
outside St Louis, MO
Something is not right, as that DTC CANNOT come back immediately after clearing on start up. You need a proper scan tool, as I suspect there is more the ECU can tell you.
In order for that DTC to set, the time stamp and warm up period has to run, and fail, twice, before anything happens. 2-trip detection logic.
oilhammer
You could have a CTS open circuit DTC stored, that would indicate wiring. You can also check what the Instruments says for temp.
Proper scan tools. Worth every penny.
jnl_public
California, US
2002 Jetta Wagon
Hey All,
About a month ago, I replaced my ALH's coolant temperature sensor (non-OEM green one). Just this last week, I was able to delete the faults codes with a VCDS. Then, low and behold, the check engine light comes back on a the code thrown is:
16512 - Coolant Thermostat Valve (N214)
P0128 - 35-10 - Temperature below Control Range - Intermittent.
Is there a simple way to check if the issue is with the thermostat?
Thank you as always.
oilhammer
Replace the thermostat. With a new neck and o-ring. I would only use OEM stuff, but if you can source a Behr or Calorstat brand thermostat, those are fine too.
