Sevenjays
HI. My 04 Jetta is putting out quite a bit of black smoke and the mileage is in the low 30s. It's a 5-speed that I just picked up. 109,000 on it. It looks stock but I'm curious about a small air line that is taped onto the large rubber hose that is inbetween the MAP sensor and the intake manifold. I traced the line and found it is sealed shut at the other end and doesn't go anywhere. I'm wondering if air is leaking out of the intake system causing the smoke and low mileage? It's a pretty big cloud when you put your foot into the pedal! The car still feels like it has a lot of power though.
Any ideas?
Any ideas?
