mogly
2005 Passat TDI Wagon
Rust free original paint California Car. 198K. Blue on tan leatherette. Fully loaded. Power: steering, brakes, windows, locks, mirrors. Moonroof. Monsoon stereo. 17” factory alloys with 4 brand new tires. Ice cold AC.
2.0L TDI (BHW engine code). Engine just had a full service: BSM (balance shaft module delete)-, german timing belt kit, h20 pump, thermostat, all plastic coolant flanges, glow plugs, cam inspected and received new bearing shells and fasteners, engine gaskets. Turbo disassembled and thoroughly cleaned inside to remove all carbon. Vanes move freely. Intake was removed and steam cleaned. All intake plumbing including the intercooler steam cleaned inside/out. Rebuilt alternator.
Remanufactured torque converter. Fresh trans in pan filter and proper synthetic fluid.
All new fluids: engine oil, trans fluid, coolant and brake. All OE quality fluids only.
All filters: oil, air, cabin and trans.
New brake rotors and pads at each corner.
Only OEM or the equivalent top shelf quality parts used.
The body and chassis are beautiful original paint and rust free. Very nice paint. No clear coat peel.
Both headlights have been recently wet sanded and polished to new condition.
Just professionally detailed inside/out.
No engine codes.
Clear clean CA title in hand. No liens or branding.
Turn key car. Deposit taken. Awaking pick up.
No engine codes.
