rotarykid
- Joined
- Apr 27, 2003
- TDI
- 1997 Passat TDI White,99.5 Blue Jetta TDI
I know we get TDI-PDs with lowered compression to lower NOx output . Could we get an increase in mpgs with a thinner head gasaket an increased compression ??
I'm convinced that the higher compression in my 1Z TDI due to the use of a thinner head gasket one called for in the specs. is the reason that I have had a consistance 20 % mpg over befoe the change .
So along those same lines the TDI-PD engines compression is lowered to reduce NOx but at a cost of mpgs . So if we were to go to the next thinest head gasket increasing compression and raising mpgs averages ???.
This would increase mpgs and raise NOx output but as I said eariler I care less than nothing about NOx but would be very happy to booste the mpgs by 10 or so mpgs .
Any input on this theroy on this idea of increasing mpgs by using a thinner head gasket to raise compression thereby inceasing mpgs working on a TDI-PD ????
