newswami
I am going to be doing some maintenance work on my 2000 TDI soon. It's going to be getting new axles, sway bar bushings, fuel filter, timing belt + etc., and flywheel + VR6 clutch.
While working on the car, I was thinking about doing some work to the exhaust system. My question is this: what can I do to the exhaust system to hear more engine (louder) and the turbo spool? I love the sound of diesel pickups at idle, with just a little bit of turbo whistle. I know I probably won't be able to get the turbo to whistle like a big rig, but is there anything I can do to the exhaust system to hear the spool, such as replacing the muffler / straight pipe w/o muffler, etc?
When I got the car, it had about 110K miles on it. It runs great, but it doesn't look like it was maintained the best. One thing I noticed shortly after getting it was the anti-shudder valve was sticking (by searching the forum after one day it decided not to start for me) and upon removing the intake manifold, I managed to get around a quart of carbon buildup from the manifold and valve (there was between 1/2 and 3/4" on each of the walls at most places). How likely is it that the cat is clogged up as well? Also, I tried to research but didn't get much relevant information: does anyone know if punching out the cat would give any gain in MPG or affect the sound?
Thanks,
Mike
Thanks,
Mike
