Well after I installed the new CV / Drive Axle assembly, and due to the broken bolt issue previously mentioned as well as the fact that I did not know enough to make sure I re-installed the 3 retaining plates, the drive axle came loose from the transmission flange. I noticed a clicking on acceleration and deceleration so I climbed under and sure enough the bolts were loose. I re-tightened but again did not re-install the retaining plates. It was good for about a week or so and once again I noticed the clicking. I kept putting off climbing under to re-tighten, as I had been traveling for work allot and wasn't driving the Bug much, and finally on the way home from work... Bam she let go again. I know, I know, it's my own fault for doing half a job. Well as it turned out another bolt had backed out completely and the 4 remaining bolts just could not hold the torque. I snapped all four in half. The drive axle popped loose and dropped straight down onto the control arm. Lucky me!!! All remained intact and I did not even manage to cut either boot. Had the car towed home, disassembled the drive axle flange off of the transmission, removed all 5 broken bolts and re-assembled. I managed to lose one of the retaining plates but was able to order a replacement through the dealer. After all of this, I was able to fully reassemble, replaced the stretch bolts with hardened bolts, torqued everything to specification and all is back to running like new. Moral of this story, take your time and ensure you do the job correctly the first time. If you break a bolt or something doesn't seem right, take the time to correct it. I managed to get lucky on this instance, but I will not make the same mistake and take the chance on my next endeavor.
