Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old April 29th, 2012, 18:58   #1
jamieson32
Default low power at low rpm
Hello all,
I'm looking for some insight into a low power problem that I have been experiencing over the past couple weeks. I have done extensive searching and reading over the past week and have come across multiple possibilities and am looking for some expert opinions.
My car is a 2002 Jetta TDI with 265 000km, sprint 520 nozzles and a TD Tuning stage 3 tune.
The car recently threw a P1556 code (Charge pressure control negative deviation) and the symptoms are as follows:
The car can cruise at high speeds on the highway but the acceleration is very slow compared to normal.
When accelerating from a stop 1st gear is pretty gutless compared to normal, 2nd is gutless until ~2700rpm and then the car really takes off. If you keep accelerating the power remains strong in 3rd and 4th gear.
I sometimes experience low power issues when driving normally in (the car isnt always strong in 3rd and 4th... but it is strong more often than it is slow).
Thanks, and I'm looking forward to hearing some opinions.
jamieson32 is offline   Reply With Quote
Old April 29th, 2012, 19:01   #2
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Could be a bad MAF? You should try to hook up with someone with a Vag-com and check to see if its working properly.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old April 29th, 2012, 19:02   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
I'd go for a leaking vacuum pipe myself, had a similar thing with my car recently where the turbo wouldn't kick in till late and it was a leaking vac pipe. The vnt relies on vacuum in order to create boost.
Seatman is offline   Reply With Quote
Old April 29th, 2012, 19:07   #4
BuzzKen
BuzzKen's Avatar
vacuum hoses, vane actuator or n75 valve.
BuzzKen is offline   Reply With Quote
Old April 29th, 2012, 19:50   #5
jamieson32
Thanks for all the replies. I am out of town this week but will try to get the maf logged when I get back. If the maf checks out to be fine, I will start looking into vacuum leaks.
Keep the opinions coming, I appreciate the help.
Old April 29th, 2012, 20:25   #6
Seatman
Seatman's Avatar
"2nd is gutless until ~2700rpm and then the car really takes off"
That line makes me think it's not the maf, usually when the maf goes it has no power up the revs, just a short burst low down but nothing above 3000rpm.
"The car recently threw a P1556 code (Charge pressure control negative deviation)"
I also haven't seen that code with a bad maf, I suspect with a bad maf reading the ecu doesn't know whether or not the boost is low or high. The most common ones for low boost are a leaking vac line or a leaking boost pipe.
Old April 29th, 2012, 23:20   #7
MoldovaDIZEL
MoldovaDIZEL's Avatar
Fuel Economy: whats that?
n75 i think
2017 ALLTRACK,470k,OMI,STG 5,R520,11mm, 2.5dp,2+ SB,VR6 axels,Euro 5 speed,e-codes, ST Coils, skid plate 17" CR7s.
98 Cabrio TD Swap,Jetta Front, Green Magic
Humberview Volkswagen Sales Manager
MoldovaDIZEL is offline   Reply With Quote
Old April 30th, 2012, 07:23   #8
OmegaRenegade
OmegaRenegade's Avatar
TDI(s): 2004 Jetta
start with checking the vacuum lines - you might have a line that has come disconnected. Make sure they are all connected, then run your MAF test. From there N75 and vacuum line (make sure they're not leaking)
2004 Jetta TDI 5 Speed 420 000km PD130 ASZ Engine
SLIGHTLY Modified
OmegaRenegade is offline   Reply With Quote
Old April 30th, 2012, 07:53   #9
Wingnut
Wingnut's Avatar
The vacuum leak is a good suggestion. The first place to look is the brake booster hose. It is the thick tube that goes from the vacuum pump to the brake booster. It is made of hard plastic and can crack. Usually it splits right at the joint:
This is the part:
This is what happens (very common):
Moving? Need boxes?
Old April 30th, 2012, 11:56   #10
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
I have been chasing some strange driving behaviour in my 01 Jetta for a while (no time to dig and figure things out). I did end replacing the turbo actuator which helped things out for a while, but ultimately didn't solve the problem. (the old one was so rusty that it rattled internally when I took it off) About a week ago, my car was getting fairly gutless. Got home and discovered that the tube I had installed years ago for my boost gauge had rubbed through and was allowing pressure to escape.
The car is suddenly much smoother and gets way better mileage. (VNT vanes are still sticky, but that will be solved at a later date)
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old September 14th, 2017, 11:08   #11
Creature503
Did this problem ever get fixed?
Creature503 is offline   Reply With Quote
Power feels low until sudden power boost at 2k rpm Sella Turcica VW MKV-A5 Golf/Jettas 30 January 1st, 2012 22:31
VNT 17/22 low boost on low rpm HELP A4 TDI TDI Power Enhancements 3 August 4th, 2008 23:02
No power at low rpm! Rydogx13 TDI 101 28 October 23rd, 2007 19:58
Low power at low RPM's Johnny VW MKIII-A3/B4 TDIs 2 May 13th, 2007 18:37
low power but hear turbo at low rpm ken.fresno-tdi VW MKIV-A4 TDIs (VE and PD) 5 April 19th, 2006 20:07
Page generated in 0.17285 seconds with 11 queries
[Output: 104.51 Kb. compressed to 88.50 Kb. by saving 16.01 Kb. (15.32%)]
