i recently noticed my radiator fan is not working. my AC also is not working. both were working fine before i hit a deer and had a shop fix the damage. the fuse was blown for the AC/climate control fan i replaced that and the fan worked but no AC. is there a relay or something for the rad fan/AC? will the AC kick on if the rad fan doesn't work? both the fuses (firewall and by coolant expansion tank) are fine. AC system has charge and holds it. AC compressor doesn't seem to kick in when AC button is pressed. any help greatly appreciated!
98 jetta
98 jetta
