Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old August 30th, 2017, 07:18   #1
dlb
dlb's Avatar
Default Timing belt / change cam ?
My mechanic is telling me I should change the cam when I get my timing belt done (probably late next yr) Car is an 04 Golf TDI .... 315K km's right now. I want to keep the car another 3-4yrs max. Opinions ??
dlb is offline   Reply With Quote
Old August 30th, 2017, 07:35   #2
2ManyKMfor1Tank
TDI(s): 2000 Jetta
Has he actually seen the cam? Not hard to take a look yourself, might save you a few bucks.
2000 Jetta TDI - Ventectomy, Defender Skid Plate, Bilstein TC Comforts, Audi TT bushings, Newsouth Boost gauge, Recaro GLI's, Frost Heater, FK Depo headlights with HID's, PP502's, DG Racepipe, Malone Stage 3, ScanGauge II.
2ManyKMfor1Tank is offline   Reply With Quote
Old August 30th, 2017, 07:40   #3
Vince Waldon
Vince Waldon's Avatar
Pop the valve cover (5 minutes) and feel the lobes of the cam. If any of them feel sharp the chamfer is gone, the cam has had it, and it certainly makes sense to do the replacement while everything is already apart to do the timing belt.
Some BEW cams last forever, some are toast at 200K. Mine has 317K and is about to be replaced during the 320K timing belt change... three lobes have sharp edges.
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old August 30th, 2017, 07:43   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
410k on my original BHW cam.
I knock on wood so often my knuckles hurt.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old August 30th, 2017, 10:50   #5
imo000
imo000's Avatar
My Passat's cam packed it in around 270K kms. #1 lobe was almost perfectly round. My '06 Jetta sounds like it needs a cam too. Time to change it soon.
imo000 is offline   Reply With Quote
Old August 30th, 2017, 13:58   #6
Vince Waldon
Wow... that might be a record.
A guy that lucky can probably run with scissors and swim less than an hour after eating... go for it!!
Old September 1st, 2017, 15:02   #7
James & Son
TDI(s): 2006 Jetta
I bought Gofaster's BRM 3 years ago with 430,000 kilometers. Original cam is in perfect shape. It has 460,000 now. When changing the timing belt compression didn't seem that good when rolling it over so the valves and possibly the injectors need some attention but with the Unitronics tune it is still a tiger.
James & Son is offline   Reply With Quote
300K timing belt - change cam sprocket? Turbodude1 VW MKIV-A4 TDIs (VE and PD) 8 February 18th, 2015 10:58
Timing Belt Change / Cam is very hard to pull through! BlueJay83 TDI 101 42 March 21st, 2007 17:24
uk timing/cam belt change basky General VW Discussion 0 October 24th, 2006 17:16
Cam sprocket question - timing belt change turbosc20 VW MKIV-A4 TDIs (VE and PD) 7 September 22nd, 2006 16:08
Timing Belt Change, Cam Shaft out of Sync! HELP! EtherNut VW MKIII-A3/B4 TDIs 9 March 14th, 2003 09:22
Page generated in 0.13092 seconds with 13 queries
[Output: 80.89 Kb. compressed to 70.21 Kb. by saving 10.68 Kb. (13.20%)]
