ANTARTI
Folks,
All I can say is that Evry needs to take a place with all the rest of the TDI Gods here on the forum.
I performed the "Evry fuel mod" on my stock TDI and gained an immediate "feels like" power increase of around 15 hp.
The generalities have been posted before, here are the details..
Cost: Around $5
How-to:
1) Bridge pins 2 & 3 on the 10-pin fuel harness with a 1.5K pot. Set pot to max resistance.
2) Start car
3) SLOWLY decrease resistance from 1.5K
4) When the engine shivers (you will know, its very obious) the mod is starting to work.
5) When at around 1.2K, drive around.. you will be impressed
6) Go down to 1K ohms, drive around.. you will be MORE impressed
I've had it down to around 700 Ohms, and the idle was marginal (terrible!) but the power was un-friggin-real. Evry says he is down to around 850 Ohms and is happy there. At this setting it takes the engine a second to straighten out the idle, but its still acceptable. I'm going to replace the pot with a striaght 900 Ohm or 1K resistor and have done with it.
Most beautiful part about the mod: As good as the price is, if you use stick pins into the harness itself (at the rubber surrounding the wires), you can pull the mod out in a minute and leave no trace.
This should be mandatory for all stock or chipped TDI's sans tuning-box (who needs a TB with this mod?).
Power is very impressive.. if you dial it to the point where idle is marginal, smoke is impressive too. Otherwise, smoke is slightly more than stock. Evry has also done the equivalent of an "electric bleed" using a similar method on the MAP sensor, and as soon as I can get a boost guage, I'm doing the same.
Thanks Evry.. super cheap, simple, and effective.
ANTARTI
99.5 Jetta TDI GL Silver Arrow/Grey Studio
Cost: Around $5
How-to:
2) Start car
ANTARTI
