lupin..the..3rd
Ok, so I'm a real newbie when it comes to Biodiesel. I have a 96 Passat TDI with 84k miles.
I just filled up with my first tank of B100 biodiesel. I filled up at the Shell station at the corner of rt 26 and rt 27 in maryland. It was $2.79/gal. I had about 6 gallons of regular diesel already in there, and pumped about 14 gallons of B100 on top of that. I guess that makes it about a B70 blend.
I've replaced the injector return lines with viton tubing. Is there any other rubber seals, gaskets, hoses, etc. that I should be replacing if I plan to run straight B100 from now on? I would really like to start running B100 all the time, but am concerned I will have problems with rubber bits going bad...
Is it just me, or does the engine run a bit smoother now??? Maybe it's just me....
Also, I use the 2 micron cat fuel filter. Is this a problem when running B100??
Lastly, my car has about 84k miles and this is it's first exposure to Biodiesel. I know biodiesel is a good solvent, and it will clean out all kinds of gunk in the tank, lines, etc. which will get caught in the fuel filter. How long should I go before I replace the fuel filter? I'm guessing it's a lot sooner than the 15k or 20k usual interval.
Thanks for helping a newbie!! Sorry if this has already been covered.
