progolfer_20
I found this one night screwing around on Ebay, it had a buy it now of $250 but now its upto $355. Its a bully dog propane injection for a TDI.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33740&item=2463078154
It claims:
WHY PROPANE INJECTION? The simple answer Quick,Effective and safe Horsepower for your Diesel engine.How on earth does it work? When the diesel is compressed in your engine it self ignites and explodes. While today's Diesel engines are very efficient in burning most all of the fuel that is injected,there is still a small amount of wasted fuel/energy. By adding precisionly measured Propane gas to the combustion mixture you can not only burn 100% of the injected Diesel the additional Propane means even more "Bang" for your buck! This results in Higher Horsepower AND HIGHER Fuel Economy. When used in ECONOMY mode your mpg will be maximised AND your Engines oil will be MUCH cleaner at each oil change resulting in increased engine bearing life.You will also notice a reduced exhaust smell whith propane injection dure to the extremely efficient burn! The drivers behind you will especially enjoy this feature.
When set into SPORT mode you can UNLEASH the beast in your Diesel engine! Adding up 25% more Horsepower and TORQUE! You adjust the amount of propane injection in minutes with this kit.
It claims:
