Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Central Regional States
South Central Regional States Local discussions for those on the South Central US. (Arkansas, Louisiana, Oklahoma and Texas)
Old January 3rd, 2011, 10:23   #61
TDiPd05
Fuel Economy: 50.1/47.x/43.1
Thumbs up Thank you Marin!
Marin, Thanks for a great job on the timing belt replacement on my 2005 Wagon (BEW). Quality work while letting me watch. It doesnít get any better than that.
Iíll add my recommendation with the others on this forum. He is very thorough and passionate. I will not hesitate to recommend Marin.
Thank you, David
___________
'05 Silver Jetta Wagon, 5-Spd, 80K+
TDiPd05 is offline   Reply With Quote
Old February 20th, 2011, 11:29   #62
kappa546
TDI(s): Nope
Marin is a knowledgeable mechanic who does quality work. Don't hesitate to use him. Highly recommended.
Andres
Andres
R.I.P. 09 Blue Graphite Jetta 6M TDI
kappa546 is offline   Reply With Quote
Old March 24th, 2011, 19:37   #63
judisjetta
judisjetta's Avatar
I couldn't pass up the opportunity to add my praises here for Marin. He just did a timing belt replacement and cooling fan replacement on my '06 Jetta TDI. His location is very convenient to my office and his genuine concern for my vehicle was very apparent. Marin is great and his prices are very fair ... he will be seeing me and my Jetta again for sure. Thanks so much for a great job Marin ... my Jetta feels brand new again
judisjetta is offline   Reply With Quote
Old March 28th, 2011, 22:03   #64
dieselfury
TDI(s): 2005
Fuel Economy: 38 city 47 hwy tank avg==> 44
where are you located and what would you charge to do a timing belt on a early 05 BEW?
dieselfury is offline   Reply With Quote
Old March 29th, 2011, 06:30   #65
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
PM sent.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old April 7th, 2011, 20:24   #66
bluelineman
bluelineman's Avatar
Default Another A+ rating for Marin.
I called him today to do the windows up/down feature with the key fob on my 2011 Jetta TDI. His shop isn't close by but he offered for me to meet him at his place since it's a lot closer & I'd avoid rush hour traffic. It worked out great. Our kids even played together while he did his work. He did the windows up/down, seatbelt idiot light & buzzer delete, all doors open with one click (instead of drivers with one click, all with two). We talked for probably 30-45 minutes while I asked a bunch of rookie questions. He's a nice, honest guy, knows his stuff & is very reasonably priced. I told him after the 10/20/30K free services at the dealer, I'm coming to him.
bluelineman is offline   Reply With Quote
Old April 8th, 2011, 17:11   #67
judisjetta
judisjetta's Avatar
Default First tank on new TB
Hi Marin!
I just wanted to let you know that my first full tank after you did my TB I drove 774.2 miles on 15.387 gallons of fuel ... that's 50.3 mpg!!!! I just had to share that with you and say thanks again!!!
Judi
Old April 8th, 2011, 22:01   #68
jetta ,97
jetta ,97's Avatar
Thank you very much. I hope it will say that way for long time. That is very good MPG.
HEX+CAN
Old April 20th, 2011, 19:05   #69
LGV2001
I am not one to hand out compliments easily, BUT Marin is the real deal! Great communication, excellent work and fast. I still cannot believe when the #3 injector was wrong on Monday at 2:00 and you had Pete build another and have it installed by noon on Tuesday. That is service! Also, 47 MPG on the trip home.
Thanks again Marin
LGV2001 is offline   Reply With Quote
Old April 28th, 2011, 14:06   #70
kbrenny
Marin did a greatjob helping me correct a speedometer / odometer that was incorrect due to larger 225 / 50 / 17 tires i had installed. He did a great job! HE had to adapt an instrument cluster value to get it right and now it is dead on with what it was from the factory.
kbrenny is offline   Reply With Quote
Old May 11th, 2011, 21:17   #71
dieselfury
TDI(s): 2005
i wish someone was closer than 4 hrs away....i need my timing belt changed within the next two weeks....... sent everyone pm's that pmed me
Old May 15th, 2011, 23:44   #72
alphaseinor
If you're in Lubbock TX then Steve in Ft. Worth is the closest to you, Marin (this thread's owner) is also a very skilled mechanic... and very well worth the drive
I could do it for you as well, but it looks like you're taken good care of so far.
alphaseinor is offline   Reply With Quote
Old May 30th, 2011, 10:32   #73
tikal
Fuel Economy: 37 MPG (~ 45% city)
I have not had an opportunity to take my car to Marin yet (I live in SE Houston) but all I can say is that he has been a class act on the phone and via e-mail. He takes his time to respond to e-mails and also on the phone. It shows that he has a passion for a work well done.
Glad for the folks in the DWF metroplex to have him around!
tikal is offline   Reply With Quote
Old June 13th, 2011, 18:40   #74
soundguybob
Martin, Do you have the ability to delete the Immo function on the Immo III FIS clusters? I put one in my non-immo (2000) variant, and the one issue I couldn't overcome was how to satisfy the Immo warning and flashing light in the cluster.
soundguybob is offline   Reply With Quote
Old June 13th, 2011, 20:14   #75
jetta ,97
jetta ,97's Avatar
Cluster Immobilizer can not be deleted but there is a way to fix this.
I sent you PM.
HEX+CAN
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
© 1996 - 2020, All Rights Reserved
Page generated in 0.17332 seconds with 10 queries
[Output: 126.08 Kb. compressed to 105.01 Kb. by saving 21.07 Kb. (16.71%)]
