Audi a6 c5 avant 2000 gearbox
Spencemeister
Bristol
Vw t25 and Audi a6 cd
Hi all, apologies if this is a repeat. I have a 2000 a6 c5 avant and would like to convert from 5 speed to 6 speed. I have been doing some research but it's all mixed.has anyone done this and would I need More than just the gearbox? It's a 1.9 tdi pd. I have seen the passat tdi GVS same era has 6 speed.
Thanks in advance
Spence
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Info on this forum is a bit North America-centric.
So it's an A6 chassis with a 1.9 PD (BEW?).
I can tell you some folks simply sway out gear 5 with a different gear, read that's not real difficult.
BobnOH
not-a-mechanic
central Ohio
I've heard they're nice. New or maybe used. Try shopping for new stuff, maybe supplier will know what bits you need, gear box, shifter, pretty sure the axle(s) are different.
Hopefully someone wh's done it will chime in.
