dunkindeso
Car had been running flawlessly before this incident, picked it up 15k miles ago. 290k on the chassis, unknown lesser mileage engine. Replaced a few things in that time. (I'm guessing this is non essential information but i'll list it nonetheless). replaced fuel filter, coolant temp sensor, mass airflow, N75, last but not least turbocharger.
scenario:
Tank is full. I'm driving for aprox 10 minutes, everything is fine coolant had come up to temp properly. Suddenly it feels how a gasoline engine would feel running out of gas. This happened in a span of 5-7 seconds. Without lifting throttle cruising 40mph, loss of power - power comes back but not as before - engine dies. I'm on the side of the road trying to restart. Youtube link will be inserted of subsequent startup attempts. Erratically gets up to 1,200 rpm, dies, big plume of unburnt diesel. I've checked fuses, continuity on harness between the IP and ECM and found no issues. ASV and EGR check out fine. Really not looking forward to replacing an injection pump.
scenario:
