Old June 24th, 2015, 10:46   #1
TDINJ
Default P2457 Code - 2014 Passat TDI
Went to autozone to have a CEL scanned. Came up as P2457. They looked it up and it is a Ford code... Researched here and found it only in the MkV forrums as an EGR efficiency issue.
I have VCDS but it's only good for the last cars I owned, MkIV TDIs.
Is this an EGR issue in the Passat CKRA engine? Or something else? Im now at about 46K miles, hopefully whatever it is, it is covered by warranty. Though I read much of the emissions stuff isn't after 30K miles.
No driveability issues, no countdown for the Adblue, and it did a regen yesterday as the fans were running at idle and idle rpm was up a bit during the process.
Thanks for any suggestions.
2014 Passat TDI SE w/Sunroof, Platinum Gray/Titan Black.
2005 Jetta GLS TDI, Reflex Silver/Black, Tiptronic Auto, Bilstein TC's, VNT-17 Turbo, RC Stage II. Traded in with 312K miles.
2000 Golf GL TDI, 2Dr, Black/Tan, 5sp Bilstein TC's GLS wheels, bigger injectors and Upsolute Chip
TDINJ is offline   Reply With Quote
Old June 24th, 2015, 17:10   #2
Lightflyer1
Lightflyer1's Avatar
A quick Google search of this site turned up:
http://devforums2.tdiclub.com/showthread.php?t=426483
There was some discussion about the passages being tiny in our heater cores. Might be something to this. Any repairs to the cooling system at all?
Old June 25th, 2015, 06:10   #3
TDINJ
Thanks for the info. Nope, no repairs to it thus far.
P2457 - EGR cooling performance fdhunter VW MKV-A5 Golf/Jettas 8 May 17th, 2017 12:17
2014 passat radio code ndamico VW Passat Family (NMS and B7) TDIs (2012+) 3 May 17th, 2014 16:56
2014 Passat TDI, What is it? AdaBill TDI 101 2 October 18th, 2013 07:01
2014 Passat TDI, What is it? AdaBill TDI 101 2 October 17th, 2013 22:15
Page generated in 0.14353 seconds with 11 queries
[Output: 57.89 Kb. compressed to 52.30 Kb. by saving 5.60 Kb. (9.67%)]
