W WillyGee Member Joined Sep 8, 2012 Location SAC TDI 2002 Jetta TDI Oct 10, 2013 #1 so my brake booster hose that goes to vacuum pump is cracked could this in any way affect the turbo? or make car go into limp? -Thanks
C Combine17 Veteran Member Joined Aug 14, 2010 Location Ontario - Hamilton TDI 2001 Golf GTD Oct 10, 2013 #2 that cracked hose will affect your brakes...and slightly your turbo too
W WillyGee Member Joined Sep 8, 2012 Location SAC TDI 2002 Jetta TDI Oct 10, 2013 #3 yeah i noticed stiff breaks
D duwem Veteran Member Joined Apr 11, 2012 Location Wi TDI 2002 Golf GLS TDI 5 Speed Oct 10, 2013 #4 Mine looked pinched, so I replaced it. I think I got it from ID parts.
Corsair Veteran Member Joined Aug 17, 2003 Location Weedsport, New York TDI 2002 Jetta GLS TDI 5M Oct 11, 2013 #5 Depending on the size of the vacuum leak, it could make a big reduction in turbo operation (as well as brake boost, of course) Vacuum pump to brake booster line MKIV ~ $43 (price may be old) http://www.idparts.com/catalog/product_info.php?products_id=785
