Missing items
Thats a big help! Do you have stuff on the right that is missing?
Okay, here is what's missing: First sheet, right side starting at the top and going straight down the right side. The identification where the pin numbers go to is what got chopped off.
Fuel Level (G) pin 2 goes to splice 269 located on the second page note: (G) is the sensor
SWasher Level (G33) pin 1 goes to splice 269 located on the second page note: (G33) is the sensor
Brake Switch (F47) pin 4 goes to T10e/4 on second page
pin 2 goes to splice A155 on second page
Clutch Switch (sort of a two part thingy, F36) pin 2 goes to T10w/4 on second page
(F194) pin 4 goes to 6/85 Starter interlock relay on second page
Brake Fluid (F9) pin 2 goes to ground note: (F9) is the sensor
Coolant Level (G32) pin 1 goes to splice 269 on second pages note: (G32) is the sensor
That's it.
Note: There is nothing missing from the second sheet other than a not. It says; Note: The GP relay is built into the enigne wiring harness and not shown here.
Now, you can look at each item (sensors, cluster, Ignition, etc.) and find where the pins go to. The splices are very important and are the numbers with a hand drawn circle around them.
The fuse panels are "off the shelf" after market items..........photos of them are posted in the Thread. All circuits are labeled (numbered) the same as in the Bentley manual!
You cannot imagine how many hours of work I have in those two spreadsheets .........and, I have complete notes on each connector/sensor/switch, etc., to back it upon! Those, I will not post.........far too many pages!
Lastly, my intent is to use the ALH ignition as a second "key," thus a two key system. It will be located out of sight most likely. If you will notice there is an * (asteric) at D Ignition pin 50b. Look on the second page at my note at bottom of sheet!
