cpearson45
I have a 99.5 Jetta with a manual transmission. I have noticed for some time that when I start off in 1st gear the shifter will pulse forward and backward about 1/4". The pulsations increase in frequeny as the rpms increase. Also there is a rattle/vibration in the shifter when in 3rd at certain rpms that will stop if I put my hand on shifter. It shifts fine and there is no noise in the trans.(other than the shifter rattle). Could this be a failing lower engine mount or possibly just needs to have shifter cables adjusted? Thanks in advance for any help on this.
CP
CP
