torc_sst_873
My 03 Jetta is exhibiting a few unusual electrical quirks. Based on what I'm reading on here, it sounds like the CCM is the culprit. I do not have VCDS, but I plan on going over to buddys to get it checked. I'll post codes when I do.
Symptoms:
-Radio is not working, but receiving power (can eject/insert CDs, but no display or sound).
-Climate control lights are not working, but climate control functions without issue. The rest of the lights on the dash light up without issue.
-Intermittent window function, I have to press the button 3-4 different times to fully get passenger window to completely roll down/up. Driver window, once it gets moving, it will fully go down, but I have to press button a few times to get it started.
Looking at the harness inside the dash, I do not see any frays, shorts, or anything that looks worrisome. Fuses are fine. These symptoms are the only electrical issues. With an hour commute one way, not having a radio is a real bummer.
If there is anything else I'm missing that I should check, prior to VCDS diagnostic, I am all ears.
Symptoms:
