Old May 15th, 2012, 11:06   #1
tdisquared
tdisquared's Avatar
Fuel Economy: 45+ on Golf, 31+ Passat, 42 Jetta
Default Upper Intake "charged" hose blew
A friends wife was driving his 2004 New Beetle TDI and she heard a loud "pop" followed by loss of power. Upon inspection, he found the upper hose leading to the throttle valve had blown off. In the process, the "tangs" that the clips use to hold it in were sheared off. When we push it back on, the engine sounds fine but, of course, it pops off at about 3000 rpm.
I hooked up my Vag-com and downloaded the following codes:
17586-Liner O2 sensor; pump current: open circuit
16683-Boost Pressure Regulation: control range not reached
18628-Oxygen sensor B1 S1: signal too high (rich)
16497-Intake Air Temp sensor (G42): signal too high intermittent
18000-Altitude Sensor/boost pressure sensor: implausible correlation intermittent
16622-Manifold pressure/boost Sensor (G31): signal too high intermittent.
I'm not new to this but since my TDI's have had very little trouble (knock on wood), I'm not sure what is a problem and what is a result of the problem. I'm tempted to buy a new upper hose, put it on and keep running.
Any ideas? Perhaps an overboost situation caused the problem or the metal tangs were weakened and blew under normal pressure?
"Diesel is as Diesel does"
tdisquared is offline   Reply With Quote
Old May 15th, 2012, 11:37   #2
TDI_G
TDI_G's Avatar
2 days after buying my TDI (2002 Golf ALH) my upper hose blew off of the intercooler throwing the pipe into the power steering pulley putting a hole in it. I JB Welded it and drove it until I found a good deal on a used replacement. Obviously your scenario is different as the pipes in the car you are referring to have clips and not clamps holding it on to the intake. There is a post somewhere about how to fix it either by putting a clamp on there or something like that. Unfortunately I can't remember exactly how it was fixed.
TDI_G is offline   Reply With Quote
Old May 15th, 2012, 12:44   #3
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Doggie collar.
And then find out why it's overboosting.
runonbeer is offline   Reply With Quote
Old May 15th, 2012, 13:05   #4
tdisquared
tdisquared's Avatar
Doggie Collar? Is that literal or a special clamp?
Old May 15th, 2012, 13:55   #5
runonbeer
It's a modified intake retainer. Search here or google
Old May 15th, 2012, 17:25   #6
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Hose blown off
For a cheaper and faster fix use the doggie leash! Check my signature on EGR to turbo hose fix.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2020
A4 Limp Mode,A4 tech.com/index.php/Category:Fault_Codes"]Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old May 15th, 2012, 20:26   #7
tdisquared
tdisquared's Avatar
Thanks! I'll try the Leash method in the morning.
Intake hose "1H0 145 838 F" phatcyclist VW MKIII-A3/B4 TDIs 28 December 28th, 2010 16:03
2006 TDI Blew UP! Part 2 "The Nightmare Begins" skiges TDI 101 9 June 20th, 2010 21:05
Differential "blew up". Help me fight VWOA. s20130 VW MKV-A5 Golf/Jettas 30 May 19th, 2009 13:03
"Honey, The Kid Blew Up My TDI" Mister Boh TDI 101 50 May 1st, 2007 06:41
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
Page generated in 0.13057 seconds with 11 queries
[Output: 82.08 Kb. compressed to 71.27 Kb. by saving 10.82 Kb. (13.18%)]
