Old November 19th, 2017, 15:17   #1
gerpeters
Default Check engine light on - Throttle Body Actuator
Check engine light came on today on my 2009 Jetta TDI. Did a scann and this is what I got. Any idea what I'm looking at here?
Sunday,19,November,2017,17:59:41:50329
VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 016 N HW: 03L 906 022 J
Component and/or Version: R4 2,0L EDC G000SG 8680
Software Coding: 0050072
Work Shop Code: WSC 00066 000 00000
VCID: 3D7B138464B537AEA1-8068
2 Faults Found:
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 66
Reset counter: 255
Mileage: 214595 km
Time Indication: 0
Date: 2000.00.00
Time: 05:34:59
Freeze Frame:
RPM: 2438 /min
Speed: 39.0 km/h
Voltage: 14.29 V
Lambda: 99.4 %
Bin. Bits: 00000000
008449 - Throttle Valve Actuator Control System
P2101 - 000 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 214608 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.16 V
Lambda: 99.4 %
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
gerpeters is offline   Reply With Quote
Old November 20th, 2017, 11:31   #2
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
If you look between the radiator and engine, the valve with the intake hose on it coming up from the inter-cooler. that valve is sticking. I removed mine, cleaned it up to where it would move free, and re-installed. was fine for a while then stickied up again in a few months. had to do it again with a hi-temp lube on the valve bushings. didn't think this was a high temp area being on the intake but the EGR valve is mounted next in line. mine has been good for a while now.
If it sticks and wont let the car run, leave your key on and hit it a few times with a wrench to jar it loose so you can get home. when you turn your key off it tries to close. That's what I had to do. the 3 mount bolts for it are star tips. not Phillips or triple square.
good luck, not a hard job. took me about 1.5 hour the first time. I removed the hose coming up from the intercooler out of car first to make it easy to get to the mount bolts on valve, that tube was kinda hard to get back into place after valve bolted back in.
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old November 20th, 2017, 11:47   #3
jetlagmech
TDI(s): 2010 jetta
check this thread http://forums.tdiclub.com/showthread.php?t=475327
there are a few others out there too.
JETLAGMECH
1946 Luscombe 8E
Old November 20th, 2017, 12:32   #4
gerpeters
Great! Thank you for the info
P0638 - Throttle Body Actuator - Help! MichVW VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 February 17th, 2016 04:34
Throttle body actuator? smittyl VW MKV-A5 Golf/Jettas 4 December 21st, 2015 10:31
Driving with a bad throttle body actuator njmnjm VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 December 22nd, 2014 12:23
Throttle Body Actuator - P0638 seabumb VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 34 December 4th, 2013 07:34
Check engine light: Throttle Body Diaphram a-train TDI 101 17 April 26th, 2007 09:24
Page generated in 0.13177 seconds with 11 queries
[Output: 64.88 Kb. compressed to 57.77 Kb. by saving 7.11 Kb. (10.95%)]
