Old November 19th, 2017, 10:42   #1
kylec922
Default Door switch question
My 06 TDI Jetta doesn't engage lights or anything when the door is open on the driver side. Would this cause for any reason the lift pump in tank to not prime even with key on?
I've had 3 pumps in now. I've tested them directly to the battery. They all work. However I'm not getting power to the pump and it runs when fuel is in the filter. This means that the power wire to the pump HAS to have broke right? Pump is grounded too. Fuel gauge works.
Does the + 12v line going to the lift pump go straight to the ecm?
kylec922 is offline   Reply With Quote
Old November 19th, 2017, 14:22   #2
kylec922
Anyone? Really would love an answer before I start chasing down wiring.
Old November 21st, 2017, 03:41   #3
blatant
TDI(s): 05.5 BRM
My 05.5 tdi driver door has the same symptoms and I have not had lift pump issues.
I am not sure about the +12v line
blatant is offline   Reply With Quote
Old November 22nd, 2017, 07:56   #4
kylec922
Thanks for the reply. Helps tremendously!
Old November 22nd, 2017, 13:22   #5
Ol'Rattler
Ol'Rattler's Avatar
The 2006 BRM doesn't run the lift pump when you open the door. It runs the lift pump for about 3 seconds when you turn the key to run. If you lift up the rear seat lower cushion, when you turn the ignition to run, you will her the lift pump run momentarily if it is working correctly.
Additionally, when replacing the fuel filter there is no need to fill the filter bowl with fuel. all you do is turn the key to run and then to off about 3 times the filter bowl will be primed and the car will start without a bunch of cranking.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Malfunctioning Door Switch--Quick Question PDJetta TDI 101 9 March 6th, 2011 20:50
headlight switch and automatic door locks question i_dont_golf TDI 101 1 February 24th, 2009 07:35
Remote & door switch question ncsucarjock TDI 101 5 September 26th, 2006 06:22
interior lights, door locks, fuel door switch prob sbrosita VW MKIV-A4 TDIs (VE and PD) 3 September 26th, 2004 22:45
bad door light switch question... rynmls VW MKIV-A4 TDIs (VE and PD) 2 December 7th, 2002 02:48
Page generated in 0.14506 seconds with 11 queries
[Output: 67.49 Kb. compressed to 59.61 Kb. by saving 7.89 Kb. (11.69%)]
