Old November 18th, 2017, 09:43   #1
blodgee
TDI(s): 2006 Jetta
Default 2006 Jetta drivers side axle movement?
I have a 2006 TDI Jetta. It has a vibration I can't seem to figure out nd neither can my dealer. I recently replaced the drivers side front axle with an OEM rebuilt from VW because the old one was moving up and down while the car was on jack stands and in gear at an idle. The vertical movement while rotating is most noticeable at the transmission end closest to where it bolts to the flange. I took it to my dealer and they said that this is ok and normal. I said the passenger side does not do this? There answer was the drivers side is shorter and thus has this effect? Can anyone comment if they have noticed this on their cars?
blodgee is offline   Reply With Quote
Old November 19th, 2017, 18:59   #2
narongc73
when does the vibration occur? a youtube video would help if you are curious about the movement.
narongc73 is offline   Reply With Quote
Old November 19th, 2017, 21:40   #3
blodgee
TDI(s): 2006 Jetta
The vibration is the worse at 70mph but I just went to get the front end alignment and they didn't even check it because they said that I have flat spots on both my rear tires. I am putting on my snows any day now and will see if that helps vibration.
Back to the axle wobble:I don't know how to do the you tube thing. I can estimate that it moved between 1/16th--1/8th inches.
I think this could cause some vibes?.
Old November 20th, 2017, 05:38   #4
narongc73
it should not cause vibrations, if the axle is out of balance, sure. I'll check mine for ya just to compare. Will let you know. I doubt flat spots on the tires is the issue here. I have uneven wear on my winters, and it causes an annoying thumb sound at lower speeds. My rear was out of alignment, which is common for the jetta's. I got the 5 year alignment, and have mine checked every year, and every time it's out of alignment by a lot.
WTB: Drivers side axle IAMCIRE Ontario 3 May 28th, 2014 19:44
2006 Jetta Drivers Side Electric out rebelfaye TDI 101 3 August 10th, 2012 23:58
FOUND: 6 speed axle - drivers side Wingnut Ontario 16 May 1st, 2012 19:16
WTB: Axle for Front Drivers side 04 Jetta Auto jettafock Private TDI Items for Sale/Wanted 4 October 2nd, 2011 18:09
Drivers side Drive Axle Price? kstef VW MKV-A5 Golf/Jettas 6 June 5th, 2008 15:18
Page generated in 0.11717 seconds with 11 queries
[Output: 63.75 Kb. compressed to 57.33 Kb. by saving 6.42 Kb. (10.07%)]
