Old November 16th, 2017, 03:56   #1
RollingCoal11
TDI(s): 2006 Jetta
Fuel Economy: 43 with a 49 best
Default hard to start BRM
Okay, I am taking another crack at this to see if anyone has any new idea. 3 different shops in town have not helped cure it.
Starting the car it will fire up, then die.Then over the next 2-5 mins of intermittent cranking, the engine will stumble and fire up. If the car does not sit to long, it will fire up normally or if it has a full tank it will fire up. Once it gets below 7/8 to 3/4 it will have this problem if it sits to long.
I was replacing my valve cover because of a broken nipple in the back and noticed the injector harness looking bad with a break in the insulation, so I replaced that as well. Car runs better but still has the hard starting issue.
Could it be and injector issue? I've heard that injectors do not go bad that often. I do not have VCDS but the shops did and they didnt see anything that they said.
any help please.
Chris
2006 VW Jetta TDI 5 spd
1997 Dodge 3500 Crewcab 4wd. Lots of parts
1936 Chevy pickup 4bta cummins project.
RollingCoal11 is offline   Reply With Quote
Old November 16th, 2017, 04:43   #2
Tdijarhead
Any chance it could be something simple? Like air in the fuel line? Starting and firing right up sounds like it has residual fuel in the pump. Then because the fuel has leaked all the way back to the tank it takes a while. That’s what I would suggest if it was a gasser. My old ford truck often does this.
You have an in tank lift pump can you hear it come on when you turn the key to glow the engine? If you can hear it try cycling the key to on, 3-4 Times and then try to start it see if that makes a difference. If it does you’ve got an air leak or lift pump on the way out.
Tdijarhead is offline   Reply With Quote
Old November 16th, 2017, 04:48   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Sounds like a loss of fuel prime to me. I would suspect the lift pump.
oilhammer
www.cardocautomotive.com
Old November 16th, 2017, 05:25   #4
RollingCoal11
TDI(s): 2006 Jetta
I pulled the line to the pump into the filter and turned the car on and fuel shot 20ft. lol
Could bad injectors o-rings cause this? I will check the whole system again from the lift pump forward next week. Try and find the leak or replace the pump.
Chris
Old November 16th, 2017, 18:21   #5
hymato
Does the car smoke after it starts?
hymato is offline   Reply With Quote
Old November 17th, 2017, 21:23   #6
RollingCoal11
TDI(s): 2006 Jetta
Yes, it is a smokey. I was told it was a bad actuator on the turbo and my stage 2 cam.
If it's related I'd love to fix it.
Chris
Sporadic hard start 06 BRM veedublub VW MKV-A5 Golf/Jettas 27 November 14th, 2016 11:21
Brm tdi hard start, no idle but will start with pedal to floor and rev up Jeeporvis97 VW MKV-A5 Golf/Jettas 27 November 6th, 2016 10:16
06 BRM TDI repeated hard stalling and now no start pedaltheglobe VW MKV-A5 Golf/Jettas 2 April 14th, 2016 07:35
2006 Jetta BRM Hard start, white smoke, knocking Mscottiel VW MKV-A5 Golf/Jettas 5 January 22nd, 2016 13:05
Hard start problem, still after going every hard start thread snowboardphil VW MKIV-A4 TDIs (VE and PD) 9 July 6th, 2013 17:31
Page generated in 0.17023 seconds with 11 queries
[Output: 73.65 Kb. compressed to 64.48 Kb. by saving 9.17 Kb. (12.45%)]
