Old November 15th, 2017, 05:38   #1
Default Turbo rebuild
06 BRM 1.9L 200K
Well my car started puking oil after deleting my EGR/cooler yesterday. Im gonna go on a limp and say I need a turbo. Any reason I can't rebuild it? What kit should I be looking at?
borjawil is offline   Reply With Quote
Old November 15th, 2017, 10:48   #2
Did the oil come from the tail pipe?
If so, yes, thats a blown turbo
Turbos theoretically can be rebuilt, however in some models the case of the tdis the suppliers dont provide with the parts or there are no competent rebuilders with the balancing equipment.
Of course there is always china. Be aware that a broken turbo can trash your engine via a runaway and that will be more expensive than a replacement turbo.
Carlos_TJ is offline   Reply With Quote
Old November 15th, 2017, 12:00   #3
Ol'Rattler's Avatar
Only if you want it to fail again shortly after. The turbo manufacturers do not sell rebuild parts for TDI's and the Chinese parts that are out there on the the interweb are pirated garbage.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old November 15th, 2017, 12:28   #4
crazyrunner33's Avatar
Even if you can get a real CHRA from Borg Warner, the rebuild for the BV39 is a bit more complicated than a '90s truck turbo, at least for a DIYer. If you can afford it, I recommend just jumping to a PD140 turbo, it's direct bolt on, robust and works well on a stock car. I already assume you have a tune for the EGR delete, so getting a tune for the PD140 would be a non issue.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old November 16th, 2017, 07:06   #5
No tune yet. On a budget so Ill have to find a used one unfortunately.
K03 Turbo for rebuild and new A3 Turbo Oil Line tychoseven Private TDI Items for Sale/Wanted 0 August 3rd, 2016 08:29
Turbo rebuild GT TDI Golf TDI Power Enhancements 11 November 3rd, 2015 15:39
Turbo Rebuild SkyRyder55 VW MKIII-A3/B4 TDIs 12 January 23rd, 2013 20:45
Where to get a reputable turbo? Or rebuild turbo? ericgray1 VW MKIV-A4 TDIs (VE and PD) 30 June 23rd, 2012 11:41
I need my turbo rebuild Curkkic TDI 101 3 January 11th, 2011 14:07
Page generated in 0.15175 seconds with 11 queries
[Output: 67.02 Kb. compressed to 59.18 Kb. by saving 7.84 Kb. (11.70%)]
