NewVWFanatic
I just did a major suspension upgrade on my Jetta Mark V TDI after 175K miles. Replaced original struts/springs with Shine Streat springs/Koni FSD, S3 solid rubber rear control arm bushings, ball joints, and dogbone mount/trans mount. Most of the bushings were shot and ball joint close to failing. For the final mod would like to upgrade stock rear sway bar but want the optimal bar for this setup. So I'm considering either 034 adjustable RSB or the Whiteline adjustable RSB. The 034 is 25mm, the Whiteline is 24mm. I plan to leave the front stock sway bar alone. Any experiences with these two bars? Thanks for any input.
