Old October 18th, 2017, 08:50   #1
phantom1260
Default Torn Axle Shaft Boot - Repair or Replace
I have a torn inner boot on the left front side. I just replaced this shaft last year. At the time I made the mistake of going with an A-1 Cardone shaft.
If I can find the receipt I may be able to exchange for a new one under warranty but I don't want to be pulling it out again next year.
I still have the orginal shaft that I replaced last year. I could just replace the torn boot on that one and swap it in.
My question is are these shafts still okay if they have been running without grease for an extended period of time. I don't remember hearing any clicking or anything on turns etc.
Do you think these shafts are still okay or should I get a new shaft from a proper supplier this time.
phantom1260 is offline   Reply With Quote
Old October 18th, 2017, 12:51   #2
aj164
Fuel Economy: 47 hwy best, 38 combined typical (~ 189000 odo.)
The old one is much better than your new one. I would clean it all up and look for rust in the joint. The boot kit will come with grease and clamps. The VW boot kit I bought from WorldImpex has outlasted whatever boots Raxles used on my driver side shaft.
'06 Jetta TDI DSG pkg#2 (215k miles)
GDE tune, RCD510 radio, rain sensor, euro mirrors, TPMS, Koni FSD, Mobil-1 TDT
TGE Inc.
aj164 is offline   Reply With Quote
Old October 18th, 2017, 14:29   #3
kbaisley
Depends!
The old OEM axle is better than a cheapie replacement axle. You need to dismantle your old oem shaft and look for wear on the joints. Running w/o grease - boot, expose to dirt, the joint will wear. If the old axle joints are good, I would fix and use that one. Replace both boots whilst the axle is out.
I try to use Lobro boots, they are an OEM supplier and they seem to hold up well.
kbaisley is offline   Reply With Quote
Old October 19th, 2017, 08:51   #4
trevinator
I would rebuild the old oem one since you have it off the car and can take your time to do it right.
trevinator is offline   Reply With Quote
Old November 6th, 2017, 06:12   #5
phantom1260
Finally got the around to doing this. I ordered a boot kit and replaced the boot on the original shaft and swapped it out. Hopefully I won't have to take this apart again next year.
Old November 7th, 2017, 02:29   #6
Ol'Rattler
Ol'Rattler's Avatar
Did you dissemble the joint, solvent clean it and do a close visual inspection on the balls and raceways? If it was run with a torn boot, dirt and water got inside and you could have just put a new boot on a trashed CV joint.
OEM CV? If it has been trashed by contamination, it could be an OEM CV that's ready for the trash. Throwing grease is really the least of your problems.
A new CV joint and a new boot is the way to go if there are signs of wear on the internals of the CV joint.
If the other boot is still intact, A clean, inspect, regrease and a new boot would be fine since it most likely has never been contaminated internally.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old November 7th, 2017, 07:46   #7
phantom1260
The OEM CV didn't have a major tear like in the pic I posted of the reman one. The OEM had the outer boot torn from the smaller clamp side. So the grease and boot were intact for the most part.
The inner boot however on the OEM was not torn but was missing the inner clamp. Someone previously thought it was a good idea to replace it with a zip tie. So I added grease and the proper clamp on the inner side as well.
I cleaned and inspected both sides before I put it back together. I also replaced the axle nut with a new one.
Whole process took me about 1.5 -2 hours and I think about $80 CDN
It might just be in my head but I can feel it driving better than the reman one.
Old November 7th, 2017, 19:25   #8
Ol'Rattler
Ol'Rattler's Avatar
And that's the rub, really. If nothing actually got inside to contaminate the joint, should be just fine. When you said torn I assumed you meant were they usually tear which is in the accordion part.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old November 9th, 2017, 09:00   #9
phantom1260
During my research for this repair I also learned that it’s different grease for the inner and outer boots.
Old November 17th, 2017, 05:34   #10
phantom1260
Before I replaced the axle with the torn boot the car was making a lot of noise on idle. This was diagnosed as a worn DMF by my mechanic. Since I replaced the axle I have not heard the noise.
Is this just a coincidence or was the axle the sole culprit the whole time?
Old November 24th, 2017, 15:33   #11
kbaisley
Typically at idle, the cv joint it not moving unless the car is moving, so I would leans towards a coincidence. If your joint was making enough racket / noise, a replaced boot would not eliminate the noise. IMHO
Old November 27th, 2017, 07:49   #12
phantom1260
Yea that's what I thought as well. I also finally put the bottom splash shield back on after patching it up. So that could just be dampening the noise.
cv boot repair or replace axle? Ackilys Ontario 6 April 5th, 2016 16:37
Drive Axle Boot Repair Mr_Deezy VW MKIII-A3/B4 TDIs 5 October 6th, 2014 18:12
Torn CV Boot Repair Options To DIe for TDI 101 13 February 7th, 2012 17:10
Torn axle joint boot jonferns TDI 101 24 December 29th, 2010 08:27
Torn Boot - Front Axle car54 VW MKIV-A4 TDIs (VE and PD) 8 May 16th, 2002 19:42
Page generated in 0.15541 seconds with 11 queries
[Output: 105.66 Kb. compressed to 88.93 Kb. by saving 16.73 Kb. (15.84%)]
