Old October 20th, 2017, 23:39   #16
Ol'Rattler
Ol'Rattler's Avatar
Back in the 60's, my dad used his manual tranny car for mail delivery and IIRC, he never really had clutch wear issues. He never rode the clutch. It was either engaged or not engaged with very little slip on engagement. Cars had bench seats back then so he put the sorted mail on the drivers side and drove from the right side. Sure looked bazaar............
Probably not the same driving situation as yours. My wife's 6 speed auto Camry is a blast to drive. She really gets P.O.ed when I come home from driving somewhere and I mention how much fun her car is to thrash.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old October 21st, 2017, 13:43   #17
Wolfdie
Wolfdie's Avatar
Nice! I do the same to my wife's 2015 kia optima hybrid. She gets 40-50 mpg. When I bring it back it has .... 20ish
Well got the crap pulled of the front. Discovered the turbo actuator is busted so either replace that or some how use it as an excuse to get a upgrade turbo
Gonna call it a day. Dam fever is kicking my ass though I want to continue....
Wolfdie is offline   Reply With Quote
Old November 13th, 2017, 18:21   #18
Wolfdie
Wolfdie's Avatar
Finally got back to work after getting sick and busy with other stuff. Yesterday I pulled the good engine. Today I mounted it to my engine stand, started pulling broken parts and inspecting it to the best that I can. To what I can tell by just looking at it the timing belt, water pump, tensioner and cam look like they have recently been replaced. Here are some pictures sorry for the crappy lighting and quality
Old November 14th, 2017, 10:58   #19
1sloVR4
Any chance you'll be parting out the car? I so need an Inner timing belt cover which was taken out from a broken block
Speaking of broken blocks...I would highly recommend replacing the upper engine mount bracket with the newer version 03G199207G. These blocks can't take the stress from repetitive removing and torquing the bolts of the engine mount bracket. As you can see, it bolts onto a little nub on the engine block and alternator/AC bracket. It's just simply poor engineering.
If that ever happens while driving at considerable speeds, expect catastrophic damage. I considered myself lucky and it only took out the upper and inner timing belt covers.
1sloVR4 is offline   Reply With Quote
Old November 14th, 2017, 14:37   #20
kbaisley
Do not use the timing belt. You have zero history on it and the risk reward is not high enough. It's cake to slam one on with the motor out. Pop in new water pump as well. I always throw in a thermostat. I would also recommend the one coolant housing on the drivers side of the head. Its 30.00 or less. It's up to you, I try and replace the common failure parts while I go thru it. The cam, you need to verify it has the chamfer edge on the lobes.
If you drive that DSG for a while, I would recommend at a very minimum, checking the DMF for play. Personally, while its out, you can throw one in for $325.00. It is really easy to do it now ;-)
You should be able to part out and pull in some dollars to cover these items. I will drop you a PM, I am looking for a cluster, ecm and a steering wheel.
kbaisley is offline   Reply With Quote
Old November 14th, 2017, 14:40   #21
kbaisley
I know the feeling.. my current car dropped the engine down when the mount broke. Took out the inner and outer timing cover, cracked tab on block, the mount and a hose. The Van Gough bracket solved the problem. (Put in a new belt, water pump, etc while I was repairing - bought it broke after ins co totaled it out for the prior owner)
Old February 21st, 2018, 20:38   #22
Wolfdie
Wolfdie's Avatar
Finally got time to get the motor in everything is hooked up and back in place. I tired to test start it and it wouldn't crank not even a clicking noise. I've checked and everything is connected properly as far as I can tell. The only thing is I did not put coolant into it yet could there be some sort of safety that wont let it start with no coolant? Just wondering cause this has me stumped...
Old February 22nd, 2018, 00:33   #23
Henrick
No.
Does the engine turn over by hand?
Are you sure the starter is installed correctly and wired up?
Henrick is offline   Reply With Quote
Old February 22nd, 2018, 17:42   #24
Wolfdie
Wolfdie's Avatar
I jumped the starter it turned the engine no problem. I cleaned the connection that goes to the starter. I tested to see if it was the neutral safety switch and still no luck. Also been looking for the starter relay and can't seem to find it
Possible Buy 2006 Jetta Project tanner VW MKV-A5 Golf/Jettas 9 April 2nd, 2017 11:35
My TDI Project vwdzi Upgrades (non TDI Engine related) 0 July 3rd, 2010 18:22
TDI Project #2 jlucas VW MKIV-A4 TDIs (VE and PD) 4 September 14th, 2009 10:41
Tdi project #1 jlucas VW MKIV-A4 TDIs (VE and PD) 2 August 30th, 2009 15:00
1.4 TDI - project impuls TDI Power Enhancements 1 November 16th, 2003 15:08
Page generated in 0.17404 seconds with 11 queries
[Output: 96.70 Kb. compressed to 82.82 Kb. by saving 13.88 Kb. (14.36%)]
