Old October 13th, 2017, 22:15   #1
maloosheck
maloosheck's Avatar
Default BRM Borg Warner BV39 vane actuator again
My actuator is leaking and I am researching options. Not too eager about the IDParts CR actuator solution.
1. Have anybody actually contacted Borg Warner to find out if we could order these?
2. Have anybody tried any of these:
https://www.alibaba.com/product-deta...690139523.html
https://www.alibaba.com/product-deta...031717269.html
maloosheck is offline   Reply With Quote
Old October 27th, 2017, 16:10   #2
2footbraker
2footbraker's Avatar
I've got a used one if you want it.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old October 30th, 2017, 19:19   #3
maloosheck
maloosheck's Avatar
Got some Chinese knock off from ebay. Chances are it will last longer than stock turbo.
http://furmanka.blogspot.com/2017/10...a-turbiny.html
Old October 31st, 2017, 04:55   #4
Tdijarhead
From Prothe no doubt? Guaranteed for 3 days or or 30 miles whichever comes first. I hope you have some type of guarantee.
Tdijarhead is online now   Reply With Quote
Old October 31st, 2017, 14:29   #5
Ol'Rattler
Ol'Rattler's Avatar
Originally Posted by maloosheck View Post
Garbage Chinese parts directly from China. Why go to E-Bay when you can get screwed at the source. https://en.wikipedia.org/wiki/Alibaba_Group
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Ol'Rattler is online now   Reply With Quote
Old November 13th, 2017, 16:00   #6
Ryan_B
I bought the one from Prothe. I had to cut off some of the braket just to get it to fit properly and then cut off another portion to get to the bolts to put it back in. I ended up using Allen bolts to make it easier when I re-installed. When I msg Prothe about the modifications I had to do to make it work he never replied. Also, this has given me a CEL that I haven't yet figured out how to 'fix'. I am getting boost now though which I was not before...
Ryan_B is offline   Reply With Quote
Old November 13th, 2017, 20:02   #7
Tdijarhead
Another prothe victim. If you havenít yet, do a search of his name on this forum.
Old November 17th, 2017, 01:52   #8
Henrick
It's not just actuator alone. The installation and proper calibration/adaptation procedure is quite tricky but very important. Othervise you will be getting CELs, bad boost performance, etc...
Henrick is offline   Reply With Quote
WTB: Borg Warner KP39 smart actuator or working turbo w/actuator vt_2005tdi Private TDI Items for Sale/Wanted 1 July 4th, 2017 16:45
used 2006 BRM Borg Warner Turbo Jesco Private TDI Items for Sale/Wanted 0 June 10th, 2017 14:05
Borg Warner VN15 Actuator adjustment Biostroker VW MKIV-A4 TDIs (VE and PD) 24 January 29th, 2017 15:23
Borg Warner VNT15 turbo actuator, etc... JETaah VW MKIV-A4 TDIs (VE and PD) 2 October 1st, 2014 13:38
Good used BRM bv39 Turbo w/actuator plus additional actuator only. 46237 newlitemotorist Private TDI Items for Sale/Wanted 9 September 17th, 2014 16:19
Page generated in 0.12856 seconds with 11 queries
[Output: 86.62 Kb. compressed to 74.71 Kb. by saving 11.90 Kb. (13.74%)]
