Old February 23rd, 2008, 17:56   #1
jcboulware
jcboulware's Avatar
Fuel Economy: 38-41 and rising
Default Radio Upgrade
If I buy a replacement Monsoon Premium 6 head unit from a used dealer or off of Ebay, what do I have to do to make it work? What kind of codes need to be changed? Has anyone else done this?
jcboulware
2004 Jetta TDI Wagon, ventectomy, DG bypass filter, panzer plate, EGR valve & cooler delete, Malone Stage 1.5 tune, Euro-tuning 6th Gear Conversion.
jcboulware is offline   Reply With Quote
Old February 25th, 2008, 19:47   #2
mtltdi
mtltdi's Avatar
Fuel Economy: 63.21/46.88/30.25
What radio do you have right now?
My Page
mtltdi is offline   Reply With Quote
Old February 25th, 2008, 20:00   #3
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
To add Monsoon to a car(and benefit from it) that doesnt already have it, you would also need to add the amp and associated wiring. And the wiring for it is far worse than anything you could possibly imagine. Aftermarket is really your best bet for a stereo upgrade.
david_594 is offline   Reply With Quote
Old February 25th, 2008, 20:33   #4
jcboulware
jcboulware's Avatar
My Monsoon has crapped out as they apparently do with some regularity. I was hoping to replace it quicker and cheaper than aftermarket with a used HU. Aftermarket however is looking better everyday.
jcboulware
Old February 25th, 2008, 21:13   #5
david_594
david_594's Avatar
Oh, if thats the case, just find a used monsoon and make sure the seller has the security code for you.
Old February 26th, 2008, 05:18   #6
jcboulware
jcboulware's Avatar
I've heard that the security code is the last 4 digits of the radio's serial number. Anybody know if that's true?
jcboulware
Old February 26th, 2008, 05:25   #7
J double R
Fail Train Conductor
J double R's Avatar
Fuel Economy: 45-50 mpg
nope. not true.
Originally Posted by meganuke
Trogdor! Burninating the TDI, burninating the peasants...
J double R is offline   Reply With Quote
Old February 26th, 2008, 07:50   #8
jettawreck
jettawreck's Avatar
You can usually get the code from the VW dealer if you give them your vehicle VIN# and the HU serial #. I have done it a couple of times. (If they won't, try a different dealer) No one in their right mind would steal one of theses units anymore, they're only worth about $75. If you have a single din and want to convert to a double then you need some adapters and lose the off @ key out.
2004 Cadillac SLS (wife's)
Old March 2nd, 2008, 20:33   #9
loneviking
I need to get the radio codes off my radio so I can install a Frost heater. What is a 'HU serial #'?
1996 Passat wagon
loneviking is offline   Reply With Quote
Old March 3rd, 2008, 00:57   #10
NFSTDI
NFSTDI's Avatar
TDI(s): '98 Jetta
Fuel Economy: 39-44.75 MPG, cumulative average 39 MPG
Head unit or radio serial number I believe. Should be on a sticker somewhere on the unit. If your stereo is original it shouldn't be that hard to get the code. Mine was on many of the receipts from work done by the original VW dealer. Try asking your local VW dealer.
1998 Jetta RC II/III K03/04 Billy HDs & SofSports
1998 Ducati ST2 FBF tune 1986 300SDL
1989 Ford E350 Diesel (7.3L International)
2004 Ford E350 6 leaker
http://www.keysforcarsberkeley.com
NFSTDI is offline   Reply With Quote
Old March 5th, 2008, 07:38   #11
jettawreck
jettawreck's Avatar
You need the radio serial # and your vehicle VIN#. Call dealer with this info and request radio code #.
Just curious though-why do you need that to install a Frost heater??
Old April 3rd, 2008, 23:37   #12
sjsgolf
TDI(s): 03 Golf
Does the monsoon drive 8 speakers? Is it 8x35? What am I going to need from aftermarket?
sjsgolf is offline   Reply With Quote
Old April 12th, 2008, 21:25   #13
greenjetta
Fuel Economy: AVG Per Tank 43//38 for 80+MPH daily on GER Autob
Can you advise why I have lost AM reception when I had installed a new ALPINE CDA-9884 radio in my 2001 Jetta TDI. The original radio AM/FM Cassette was removed and the Alpine was installed.
The radio dealer is telling me I now need an AM booster. Is this true?
greenjetta is offline   Reply With Quote
Page generated in 0.16317 seconds with 10 queries
[Output: 112.08 Kb. compressed to 93.36 Kb. by saving 18.72 Kb. (16.70%)]
