Old November 14th, 2017, 12:17   #1
Bobs2293
TDI(s): Mk5 Jetta
Default Fuel Temp Sensor
Hi Guys
(1.9TDI PD engine)
Hopefully you can help!
Recently had my check engine light come on with the code P0183 fuel temp sensor. I have changed the sensor and reset the light but the fault light comes back.
Have now tested the old sensor with a multimeter and it appears to work with the resistance changing during a temperature input.
Have checked other sensors on the engine with the ignition on,they are all getting a 5V supply.
However my fuel temp sensor is only getting a 2.5V supply but it is showing a good earth. So the wires not broken.
Any ideas on a next step. I'm stuck for ideas.
Should it actually be a 5V supply?
ECU fault?
Is there two fuel temp sensors?
Man many thanks in advance!!
Bobs2293 is offline   Reply With Quote
Old November 14th, 2017, 12:58   #2
dandywriter
I searched the A5 forum for you. Found this thread:
http://forums.tdiclub.com/showthread...el+temp+sensor
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Fuel temp sensor craig01b VW MKV-A5 Golf/Jettas 0 May 11th, 2017 15:34
Fuel temp sensor????????? nsadoc TDI 101 2 October 17th, 2009 13:28
Help: Where Is My Fuel Temp Sensor west5971 TDI 101 1 December 18th, 2007 11:02
1999.5 fuel temp sensor G81 and displacement sensor G149 freebirdtdi TDI 101 9 March 22nd, 2007 10:08
Coolant temp sensor vs. fuel temp sensor Jimwsea TDI 101 0 May 16th, 2006 05:54
Page generated in 0.14411 seconds with 13 queries
[Output: 52.66 Kb. compressed to 48.68 Kb. by saving 3.98 Kb. (7.56%)]
