I just finished replacing all 4 wheel bearings, both axles and the brake soft lines. The car is a LOT quieter in a straight line now, since the old bearings (200k miles) were no good. The axles were original as well, with torn boots, so I figured I would replace them while I was in there. The axles were purchased from ECS, under the GKN brand.
Aside from the packaging being a bit beaten up when I received the stuff, I did notice that the outer joints of the new axles had a slight clicky / detent feeling in them as I pivoted them by hand. The inner joints did not do this. If only one axle had done it, I would have assumed it was defective, but since both did it in exactly the same way, I figured that they were worth a shot ("they can't BOTH be bad, right?"). So I got it all back together this evening, all stretch bolts replaced with new ones and properly torqued to spec, and went for a test drive.
When turning the steering wheel more than ~15 degrees and applying any amount of throttle, I get LOUD clicking, almost clunking, from the front left side. It is easily heard, and can even be felt. The right side does it as well, but less so.
Anyway, this strikes me as what a classic symptom of a failing CV axle. Has anyone else had one or both axles be defective from the start? I am sort of not excited about doing an exchange on these if the quality is this bad. It isn't like axles "break in" either, correct?
